Shahzad
- Canada and USA
- Electrical Engineer
Hello,
As we know normal induction motor name plate has fixed frequency mentioned on it so a calculated, designed heat will be produced by it. However, if we have a inverter duty motor or a motor driven by VFD and we want to use that motor in Hazardous classified area, then being inverter duty motor, frequency will be changing as per PWM VFD technique. Is there any special requirement for inverter duty motors? As we know that a motor and VFD combination changes the characteristics of the motor in terms of amount of heat generated by it which may create a safety concern from explosion point.
How should we design an application of Motor + VFD for Class 1, Division 2 areas?
