I was looking at a controller for a hydraulic valve the other day and noticed that the controller seemed to supply a mA output current (up to 800ma) to a solenoid which controlled a hydraulic valve. I found it strange that a mA output was being used directly to control a coil for a valve. The voltage rating of the controller was 24VDC.
The coil on the valve was a DC coil. I guessing that the ouput current supplied a varying current to the coil and therefore a varying power to the coil to make the valve move between different positions. Has anyone ever seen this control direcltly on a valve or coil before? Can you explain relationship between current output, voltage ouput, power across coil and resulting coil movement? I'm assuming that coil impedance is fixed.
