solaeros
- Beautiful IDAHO
Ok I'm told you can't run a lower rated lamp from what the luminaire itself is rated for ie: 250 watt MH Lamp in a 400 Watt MH Luminaire. I don't understand this, to me it's like saying you'll burn up a 100 amp service if run off a 100kva transformer. Shouldn't the lamp create the load and not the ballast? Would it be a capacitor issue? Could it be a wives tale?
