the maximum available fault current at the transformer secondary terminals is estimated to be 21110 symmetrical amperes at 120/240 volts. The protective device on the line side of the transformer currently in place or to be installed and serving your property located at the subject location is a 8 amp type K fuse. The primary service voltage is 7.6kV L-G |
90 ft in pvc 1/0 aluminum triplex from transformer to meter.....
calculated 5687 amps..
Does that sound correct ?
