zcanyonboltz
- denver
Quiz question I need some help understanding. You have a 3-pole 200 amp panel with 3 hot conductors and another that is connected to the neutral bar. None of these four conductors have phase tape. You check with your voltmeter and get the following readings.
A to neutral =120 volts
B to neutral =120 volts
C to neutral =120 volts
You now know the system is:
a. 120/208-volt, 3ph, 4-W b. 120/240-volt ,3ph, 4-W
I'm not sure how to rule out one or the other. Any teachings are appreciated. Thanks
