petersonra
- Northern illinois
- engineer
I can't edit the post, given that ten minutes have passed.charlie b said:The moderators have been recently discussing the notion of new posts that contain nothing but a link. We haven't made any recommendations to the owner yet, but we are generally not in favor of allowing it.
Bob, may I ask you to either post a comment (after this one, to keep things in context), or to edit your original post, to give at least a sentence or two that describes where your link will take the reader? The consensus of moderator opinion is that the reader should have some reason to decide whether or not to click the link, and that the original post should give some type of description.
Thanks for your understanding.
Very expensive is a relative term.wireguru said:neat, but i bet it is VERY expensive.
Which is not all that bad. Its not something you would put in a residence in any case.don_resqcapt19 said:It is listed as tray cable so the installation has to follow the rules in Article 336.
petersonra said:Very expensive is a relative term.
If I can pre-assemble and test it at the factory rather than doing it in the field, there is potential to save a lot of field labor. Field labor is very expensive and inefficient.
I think the more labor I have under my control the better. For the most part, a machine manufacturer is not allowed to do a lot of the field labor themselves, and ends up being at the mercy of whatever contractors they are forced to use. Hooking up a few connectors is something that is unlikely to be frowned on as "work". Running conduit all over the place is. Even trying to test the field wiring is often considered "work" that has to be done by the contractor. And the testing is often not a lot better than the work done in the first place. If the work is done right, the testing is usually smooth. If the work itself is poor quality, the testing rarely finds everything. I have found that for the most part, anything that can be done to avoid field labor is usually cost effective.iwire said:So you think it goes in without labor?![]()
In general the labor costs have to be very high before a lot of this pre-fab stuff starts to make economic sense.
Obviously, they were not made by us.iwire said:As far as the 'test it at the factory' that sounds good but I don't see that as really happening. We often get prefabed electrical rooms and they arrive wrong. We end up re-wiring them to match the prints.
petersonra said:. Hooking up a few connectors is something that is unlikely to be frowned on as "work". Running conduit all over the place is.
Obviously, they were not made by us.We have a very low rate of that kind of thing.
It is very pricey to fix stuff in the field.
We do get switchboards and MCCs that have errors in them that we find while modifying, wiring, or testing them. Not real often, but not unheard of.
I don't consider the area lighting part of my equipment. The machine does not care if the lights are on or not.iwire said:Not really following you.
Here if you install electrical equipment for power and lights for a fee you need a license, permits and inspections. Even 'Re-locs' are wiring method covered by the NEC.
