PetrosA
- Lancaster, Pennsylvania
I'm stumped. I had a service call today to repair a few two-tube wraparounds in the second floor (finished space) of a two bay garage. When I got there, it turns out that the whole project must have been done by a handyman or homeowner at some point in the past - white conductors in the NMs were used as hots; each of the three lights was on a separate switch; there were three handy boxes for the switches with individual conductors passed through adjacent KOs, and the worst was what I saw when I took the cover off the ballast compartment: the black and white wires from the ballast were passed through a 1/4" hole in the top of the fixture and disappeared into the ceiling. The one fixture didn't work at all, so I got my pencil tester out, which rang on the white wire. I checked the switch, and sure enough it was bad. I repaired the switch and the light worked again. Out of curiosity I put my pencil tester against the frame of the wraparound and it lit up. At that point I decided I'd better make sure that I was seeing juice on the white so I got my meter out and an extension cord to get a good ground... or so I thought.
And here's where it gets weird. Building is supplied with 120/240 single phase. Sure enough, the extension cord showed that the neutral slot was hot just like the lighting circuit, and the ground and hot slots were not. From neutral slot to wraparound frame my Hioki showed 265V, but it's a high impedance meter so I went and got my Agilent U1272A. It showed 359V on high impedance setting, and zero volts on the Low Z setting between frame and any of the slots on the cord. Based on that reading, I don't think there is actually dangerous voltage on the light but I am really confused at the high impedance readings I got on both meters.
I've seen phantom voltage many times, but it was never higher than phase to ground or phase to phase voltage. Why would I be seeing a reading that was higher than phase to phase on a single phase service? At first I thought that maybe the lighting and receptacle circuits were on opposite legs, but the zero reading in Low Z mode should have shown me something in that case.
I phoned the property manager and let him know there are electrical issues in the building and that I would send him a report to pass on to the owner. In the meantime I'm hoping someone here can shed some light on those readings for me.
