What conditions would cause a motor to experience locked rotor condition? I understand starting in-rush is an example, but are there any other times? The reason I ask is because I am looking at the loading profile for some motors that are fed from a generator, and I want to understand the worse case impacts. Since the motors are VFD driven, there is no additional starting in-rush. But what if there is a locked rotor condition? What would cause the motor to stall in this case? If it does stall, would the VFD turn off and disconnect the motor? I want to ensure this doesn't put a huge load on the generator in this scenario.
