I've seen and heard alot of cases where a VFD shielded type cable was used between a vfd and the motor. I've heard some people state that this type of cable was not necessary while others have stated that it is. I'd like to get a better understanding of why and when to use VFD cable between the drive and motor and have the following questions. (All questions are based on 480V VFD applications)
What is the purpose for using a VFD shielded type cable? Any references or theory explaining the reasons would be helpful. I've always understood that it was to prevent coupling VFD noise as a result of the PWM waveform onto other equipment and cables?
Is it o.k. to run cable connected to a vfd in the same conduit as other cable on non-vfd applications? If it were a case where they had to be run together would it help ot use a VFD type cable for the cable connected to a vfd?
If a cable was connected between a vfd and a motor in and the cable was in a conduit by itself and the motor was in a location by itself, then is there a need to use a vfd cable?
