I am looking for opinions on a problem we routinely have as Building Automation contractors when controlling 460V VFDs. By code all the wire that we have running into that VFD enclosure needs to match the insulation rating of the highest voltage conductor which to make life simple is 600V rated wire. It is not a big deal when it comes to signal wire since we can just have them run 600V or 1000V THHN. But the communication bus wiring whether BACNet or Modbus is a challenge. 600V rated wire for that application is available, but it is expensive with a very long lead time. And usually our electrical subs don't realize this until they are supposed to be starting up the drives.
Has anyone utilized a product like this...
https://www.techflex.com/prod_ag.asp
that could be used to sleeve normal 300V rated wire inside that enclosure and had it pass through electrical inspection? I don't see any huge issue as long as it is from the entrance to the drive up to where the comm bus wires terminate on the strip. I am sure many times the sub has just run 300V wire and never told us and has gone through inspection with no problem, but would like to have a solution that we can pull out and use to make sure we are meeting code on all jobs.
Thanks.
Thanks.
