From panel CB, we run circuit to a VFD on 1st floor and extend the wiere to a non-fused disconnect on roof, then to a motor (also located on roof). If the motor is running and we turn off the disconnect, what will happens to VFD? Do we have a low voltage/signal wiring between motor and VFD so when the power is off at motor, the VFD will do something to avoid damage itself?
