titan1021
- Northern California
I've install (3) WEG CW300 VFD's in a cabinet and need to add a cooling fan to the enclosure. While I don't normally work with VFD's I didn't want to send a long time client elsewhere for this project. I did my homework and have everything up and running well, except that I can't find much information on using the SPDT controls for an external device.
What I plan to do is install a 4" cooling fan in the side of the enclosure that will come ON and run while one of the VFD's is in use. They use all 3 at the same time so any of the 3 will work. I can't find anything with the basic wiring from the digital inputs and or outputs, or anything about how to accomplish this.
Do I need to supply control voltage to one of the inputs on the VFD?
Thank you
Thank you
