I have situation where I'm using 100A RK1 fuse for 60HP motor @480V (Chiller Pump with VFD controller). The bussman recommend to use 110A RK1 fuse and 100A RK5 fise for this size. I want to use the 100A RK1 fuse so I won't use the 200A switch. I have been told since I'm using a VFd the input current for the drive will be less than the motor, with that said, I could use the 100A fuse because the VFd will provide a soft start. Any thought on if the 100A RK1 fuse will work or I better use the 100A RK5 fuse. Thanks for your thoughts in advance...
