Shaneyj
- Katy, Texas
- Project Engineer
I'm working on a design with requirement of 1000 hp pumping capability.
The pump must operate at different speeds so we're using a drive.
The drive max output current is 1300A.
The drive manual is calling for 5 parallel 350s (185mm) from drive to motor.
But the pump will be limited to a fixed power output.
At 1000 hp, accounting for 125% continuous load, current calcs come to about 1050 amps. (600v, .9 pf, 95% eff)
I'm using type P cabling so ampacity per IEEE 45 OR 1480, 95 degree column (depending on which cable mfg cut sheet is being looked at both of these standards show up with associated current ratings). As an aside an explanation of how those ampacities are derived is appreciated.
The drive manual is providing for full 1300A output with its recommended cabling.
Am I missing something if I provide only for 1000 hp output besides limiting drive capability?
Sent from my SM-G965U using Tapatalk
