We have a 480V 10hp VFD with an 480V-480V isolation transformer on the line side of the VFD. The transformer has both a delta and wye winding.
The engineering drawings that we have show to connect our incoming 480V power to the wye side windings and connect the outgoing side to the VFD on the delta windings. The wye side windings has a center tap but the drawings show not to use it. The ground basically is not used on a transformer connection and passed right through to the VFD. (The transformer casing is grounded)
The thing that is confusing us in the field is that the wye side is labeled with X terminals and acts as the transformer priamary and the secondary is labeled with H but this is the way the drawings show it wired.
I'm not familiar with isolation transformer connections as was hoping someone could explain this connection and how it works. Is this the right connection?
