Designer69
I am reviewing some drawings for comments and one thing I noticed is they went kind of wild on the VFD's.
These following loads have all been specified VFDs:
3HP Boiler Pumps. 480V/3PH
Electric Reheat Coil. 80KW/3Ph
Air handlers as low as 4HP. 480V/3PH
Does this seem normal to you guys based on your experience? Maybe nowadays VFDs are a lot more common even for smaller loads? Also, I cant see why you would put an electric heater on a vfd.
Is there a cutoff where you specify VFDs and where you don't, say 100HP and up?
Thank You
Thank You
