megloff11x
I have a 480V motor system that is not surprisingly picking up high frequency noise bursts at the VFD PWM frequency. I really knocked it down on the rigid frame with some moderately expensive multiply layered shielded conduited cable designed just for that purpose. However, I have some moving parts that are still good antennae because their moving coupling is not well bonded to the return at all frequencies, particularly the higher ones.
My own understanding of knocking down noise is that you need to provide a low impedance path back to the noise source's return point (usually grounded) for all frequencies. A fat wire is fine for low frequency but is an inductor and high impedance for high frequency. High frequency needs planes or conduit or braided shielding or all of the above and just the right geometry.
Does anyone have any solutions they'd like to share for mitigating noise pickup on moving metal parts?
And would anyone like to comment further on noise reduction strategy from a scientific basis?
Matt
Matt
