The graphs are in 'per unit' values. Add a couple of zeros and you have 'percent'. So '1' on the X axis means '100% speed', and '1' on the Y axis simply means '100% rated torque'.
The blue line is the rated torque of the motor/VFD combination. Torque remains constant as speed changes. This means that the motor/VFD combo can provide full rated torque from 0 to 100% speed.
The red line is the maximum permitted overload. You can overload to 240% of rated torque except at low speed where the peak overload is reduced. This limit is probably set by semiconductor cooling. You can only overload like this for a very limited amount of time.
The green line is power output. Since power is torque times speed, the upward slope is obvious. Full torque at 0 speed is still 0 power output, full torque at full speed is full power output.
-Jon
The one flaw I see in that chart is that the green line is not LABELED as "Power". I agree with Jon that it is showing power (kW or HP), because the values displayed track what I know, but it might have been helpful to the uninitiated if whomever made that chart were to have been more clear....
-Jon
If one were to continue that graph to the right, you would have also seen that as you keep increasing speed (the X axis) beyond the rated speed of the motor (the yellow), the blue line would start to go DOWN, and the green line would remain flat.
Side note; the red line showing 240% as an overload capability is a bit optimistic, or the chart is only reflecting the MOTOR capability. Most VFDs will either Current Limit or trip off line at 200%in 2-3 seconds. You MIGHT get a brief by spectacular spike of 240%, but it's not that realistic.
