We have 5 vfd rated for 75 hp each that control 5 sump pumps rated 97 amps [nameplate]. Found each motor did not have their veristers wired into the circuit so the vfd does a calculation to determin the vfd should be shut down anytime it ran at 60hz for any length of time . At full speed the current reading was always 104 amps. or more confirmed by two amp meters. These motors are rated for 460 900 rpm , Looks like the installer who install these units left the veristers unwired on purpose. Any idea why the vfd's would pull more then the motors flc ? This problem only started with these new vfd's. Thanks for any help .
