skeshesh
 - Los Angeles, Ca
We're designing an HVAC upgrade to a facility. Mechanical engineer is using 4 new air handling units which consist of a supply fan and a return fan (10hp, 5hp respectively). The package manufacturer will provide circuit breakers for each individual VFD and the control scheme allows for only one motor (fan) to operate at a given time.  I was wondering if it's required per code to provide an external disconnect for the entire package or if the circuit breakers can be used as the disconnect means.
