Hello all,
First of all, I am not an Electrical engineer. I am a Mechanical and a Software engineer, that understand and has only been working with low voltage controls (as in 24VDC and +/-15 VDC instruments, but a complete dummy when it comes to 3 phase AC. I have asked this question in many other forums and I am still at a loss as to all the various explanations that I have gotten.
Just one scenario that I would like to get clarified.
Facilities Power:
400VAC, 3 Phase, 60Hz 4-Wire Supply (Yes, 60Hz and not 50Hz). A FACTORY IN THE US.
Equipment:
Motor specified as; 230/400V Delta/Wye at 50Hz.
My Question;
Using a VFD with an input voltage of 3 phase 400VAC at 60 Hz, Can I control the motor above in a Delta configuration where motor voltage is clamped at 230VAC and at 50Hz, while VFD input is at 400VAC 60Hz?
Thanks.
Facilities Power:
Equipment:
My Question;
Thanks.
