I have a vfd that is blowing main input fuses and the driver boards are good , the question I have is how do I check a semi conductor scr. In the old days I would use a ohm meter and check each diode for high or low resistance. This is a cutler hammer 7000 series 18 pulse vsd for a waste water pump.It has two diode internally in one block or unit. Thanks
