Simonsglwc2
New User
- Chicago
Good Morning everyone. I have read many of the threads on this forum and was looking for some experienced opinions on the titled topic.
We fully understand the benefits and possible side effects of using VFD units. Particularly the issues of reflected waves. Got it. we understand the electrical theory. The issue we have is the issue of the motor terminals themselves. The terminal block is an insulation block with metallic threaded stud of either mild steel or brass and an assortment of nuts and washers attached to the cable lugs that are attached to the VFD output cable. Connecting the cable lug to the terminal block entails placing the cable lug over the stud and securing in place with nuts and washers to provive a secure electrical connection. Our question is , has any one ever documented the actual values seen at the motor terminal as a study?
The use of the motor teminal assembly and the cable lug with its through hole that may or may not fit snugly arond the stud seems to rely on the surface area of the cable lug flat pad and the surface area of the nuts If we add in the mix of dissimilar material , steel , brass and copper , and not perfectly fitting components as well as factoring in the copper condcutor in the cable and its grade and stranding is this a part of the problem, that is stated in white papers on these issues?
The next question is would a purpose designed connection, all copper ,or all brass with a matched fit be beneficial, to reducing the reflections back fom the motor to drive? Essentiallly getting as close as we can to an uninterrupted run of cable from the motor to the drivem which is unrealistic in reality.
It just seems that the existing termination method is an old solution suited to 60 Hz sinusoidal systems and not neccessarily best suited to modern power electronic driven systems with in field termination requirements.
Looking for some feedback if anyone has time
Thank you Have a good day everyone
