I wanted the forum's opinion on this one. I've been digging into the differences between a soft start vs a VFD, when it comes to starting a motor. From my understanding a soft start limits the output voltage going to the motor, which then significantly reduces torque. While on variable torque loads this may be fine, but on constant torque loads this can pose a challenge, because more torque is needed. A VFD varies the output voltage going to the motor, as well as the frequency during start-up, which allows reduced inrush current while still providing more torque. We're installing centrifuges which we don't plan on varying the speed on once it reaches full RPM. Historically, I've used soft-starts for anything I'm not wanting to vary the speed on. On some centrifuges I recall that the start times were pretty high (2x-3x FLA for 5-7 minutes, or something similar). I would think this kind of start profile is harmful to motors. Would a VFD be a better option to help start constant torque loads such as centrifuges? From everything I'm gathering the inrush current during a VFD ramp-up hardly goes above full-load amps, is this correct?
