sg000
- United States
Hi everyone. First post here. First off, please forgive me, i'm no EE, I just play one in my spare time because I have the best background in the company and the genes (father was an EE). I'm MechE by education.
This situation has a couple of questions I really could use your help, and my information sources are not really helping.
Situation: 10 HP WEG Motor on an Omron VFD (460V, 3 phase) driving a gear pump. 22 Hz, 12.9 A, 667 RPM, 152V, 3.4 KW power draw. We're at the top of the amp limit for the motor already at only 1/3 the speed. Its just gets worse as we go faster.
Initial impression: We need a bigger motor. Ok, I can live with that, if thats the right answer. I just don't want to go bigger if I don't have to and there's a simple answer in how the motor is controlled by the VFD.
Second impression: Some setting in the drive is causing this? We are running at constant torque mode on the drive, I think. I've been reading, and every time constant and variable torque comes up, pumps are instructed to be run in variable. Problem is, that doesn't make much sense to help my situation because it will output less torque, less voltage and raise the amps at this speed, not lower the amps. Am I WAY off here?
Alternate issue: I asked local supplier for motor recommendations for a 15hp, and I have a choice between a 10:1VT/10:1CT and 20:1VT/10:1CT. Thats what lead to my research on constant/variable torque. My problem is, I have no idea which one is better for me!
Any help would be appreciated! Thanks!
--Scott
--Scott
