brother
I was informed that the new NEC requires special cable/wiring for VFD's. I have seen the manfacturer instructions that require it, but not the NEC. Can someone please help me locate the NEC requirement?
Thanks.It is not a requirement of the NEC.
We had special Allen Bradley drives designed just for newspaper printing presses to most of the time act as a brake to maintain pressure on paper. While at the A&B class on these drives was told it took 10 man years to program. All of these 15HP motors were feed with common THWN. building wire with no problems. A&B never said anything about using overpriced special shielded cable.VFD cable is a scam. Belsen among others should be sued for false advertising. It is that bad. Allen Bradley has repeatedly told customers they must install VFD cable to fix issues with bearing fluting and reflected waves, then claim it’s an installation problem or a motor problem or some other lie to cover for the fact that the VFD cable did nothing to address the problem.
I think if you read carefully the manufacturers instructions don't actually require it. It is merely a suggestion. It is not a code requirement.I was informed that the new NEC requires special cable/wiring for VFD's. I have seen the manfacturer instructions that require it, but not the NEC. Can someone please help me locate the NEC requirement?
I don't think it is quite to the level of scam, but it is overhyped as a solution to what are non-existent problems in most applications.VFD cable is a scam. Belsen among others should be sued for false advertising. It is that bad. Allen Bradley has repeatedly told customers they must install VFD cable to fix issues with bearing fluting and reflected waves, then claim it’s an installation problem or a motor problem or some other lie to cover for the fact that the VFD cable did nothing to address the problem.
In any case from what I can see, most people don't install it properly anyway.
I thought it was basically swa cable with foil shield.Plus they charge roughly 400% of the market price for what amounts to 2 kV foil wrapped cable and the profit motive is the clear case for fraud which is the “intentional misrepresentation of a material fact for the purposes of material gain”. If it’s not outright fraud I don’t know what is.
