LHarrington
- Saginaw Bay area Michigan
Good afternoon,
We are working on a 200hp compressor with a VFD from Cutler Hammer. We have had intermittent VFD COM FAULTS showing up and shutting us down. We have communicated with the manufacture and they are stating my ac voltage at the I/O module could be causing the problem, which is riding at 25 to 27 VAC. They are suggesting I change the primary taps on the main control transformer from H1 and H4 to H1 and H5. their goal is to reduce the secondary voltage on main control trans to lower than 120 VAC in turn will reduce the 25 to 27 VAC to around 22 to 24 VAC which the I/O module is requiring. Has anyone else had this problem or think this is a legitimate approach a solution? The compressor in question is one of two in a series and they talk all day long to determine who needs to be the trim machine and who in standby. The equipment has the ability to see fault and log them, which has been recording errors but has not shut me down yet today. However, I would prefer to correct the problem so I can relax. We have even had a situation where the display screen has locked up and you have to cycle the power to recover. In comparison to the identical machine, all of the voltages are the same but it does not have this problem.
Thanks for your time
LHarrington
LHarrington
