bure961
- Farmingham, MA
There is a asd EATON svx 9000 for a 75 hp 480v motor / pump, it is in a cabinet with other controls. The asd is rated for 75hp and anytime it runs at a steady 60 hz for a long time it trips out on motor over temperature. The motor does not have the thermistors connected to the asd , wiring was completed by contractor. Motor draws over 99 - 100a, it is rated for 96a . Looks like the contractor did not connect the thermistors on purpose. Can the drive be setup to operate at a lessor frequency then 60hz so it does not trip out ? Any suggestions will be appreciated. Thanks for any help here.
