slice
- Massachusetts
Hello,I was wondering what the accepted practice is for sizing a feeder if you had for example one regular motor and two motors controlled by VFDs. The section on variable speed drives requires feeders be sized at 125% of the input current to the drive. How would this work if you had say a 10hp non vfd motor, and a 3 and 2 hp motors controlled via separate VFDs?
Would you take 125% of fla of the 10 hp plus 125% of the input currents of the vfds?
Or would you just take 125% fla of 10 hp motor plus 100% of the input currents of the vfds?
I believe the NEC isn't very clear on this point unless I am missing something, in which case I hope you guys can enlighten me.
Thanks for your help
Greg
Greg
