I have some questions as well as a plan that I would like commenting on if anyone has any experience or thoughts with such a setup. The environment is an audio/video facility.
The racks that the equipment is mounted have a ground stud in the bottom of the rack to bond the chassis of each piece of equipment to and to bond the racks together. There are copper buss bars that are sold which serve the purpose of bonding individual pieces of equipment to and then having one connection to the grounding stud. Can I get rid of the stud altogether and just do runs from each piece of equipment to the grounding stud? I?m having a hard time thinking of what the difference would be except for the ability to get a good connection (ie. 1 connection from buss bar vs. many from each piece of equipment). I just don't want to unnecessarily spend money, but I don't want to cut corners that will put me in a bad place either.
In general I?m trying to finalize plans on a facility bonding/grounding scheme and am going back and forth having had my own past experiences as well as having done a lot of reading on the subject lately on the method of grounding and bonding. There?s a lot out there from specialists that seem to imply that IG isn?t really worth it in A/V facilities. Then there?s star grounding vs. non-star grounding, and not much definitive information on the proper methods for grounding and bonding an A/V facility. The last facility I was involved in (not the grounding scheme thank god) had IG receptacles throughout, dedicated technical panels, isolation transformer, technical star bonding and grounding and still had major noise issues. That has put a bit of fear into me about how to move forward on a project that I am responsible for. Not to mention trying to look at cost/benefit factors. I don?t want to spend a bunch of money on wiring up IG if it?s not going to improve the system performance.
Here?s what I?m looking at doing now. Maybe someone can comment on this ?
1. Right now I?m looking at bolting together the racks using ?? bolts (sanding down to bare metal at the bolting points) and lock washers to bond them together.
2. Having the copper buss bars mounted inside the rack using insulated posts with each piece of equipment tied to the buss bar using insulated ground wire, and the buss bar tied to the bonding/grounding stud.
3. Having a main technical ground strap running past my equipment racks to the technical panel IG buss bar. There will be an additional grounding strap from the grounding stud of each rack tying into the main grounding strap. The main grounding strap will be run inside of EMT conduit or Greenfield.
4. I?m also looking at doing IG circuits and running the isolated ground back in the conduit with the main lines. Mounted on the inside of each rack would be an IG power strip using insulated posts. Can I tie power strips from multiple racks together if the amperage doesn?t exceed the capacity of the circuit? Is there a recommended method of doing this if so?
5. I?ve also heard mixed things about HAVING to tie all equipment to one phase for an a/v facility. The approach seems logical for small setups, but a significant setup would throw the power system way out of balance if it were all on one phase. I?ve had people swear that if this isn?t done things will go all wrong though. Does anyone have any experience with this?
6. I?m not doing computer flooring and was just going to mount the racks on 4? x 4? wood beams to give me room to run cables. Would this potentially cause any issues?
Thanks for your thoughts!
Chris
Chris
