DansProfElec
- Huntington beach, CA
Hello folks,
I have a job to repair the vintage overhead wiring feeding 3 seperate buildings from a 3 meter panel, with a 2 pole, 30 Amp main breaker for each building ( 1 story, aprox 450 to 600 Sqft. each). The customer does not want to go underground and each building is aproximately 15 feet apart. He wants the wires all above ground from building to building (like it was before). These buildings are fed with 3 #10 Awg wires (hot, hot, neutral, no ground). Each unit has a 30Amp Main cutoff at the meter and a small sub panel in the building. I have attached a picture for your viewing pleasure. I do not know of anyone who sells triplex in a #10 and I don't know if it is legal to run #10's like they did in this 1930's install.
Before I tell the customer that I can't do it, anyone have any thoughts?
Thank you for your help.
Dan
Dan
