TCHernandez
- Tampa, FL
www.flickr.com/photos/hershamboy/3174416455/
I have had been told that we are in violation of NEC 230.2 in having more than one service on a single structure servicing 9 tennants and one House. The photograph shows 3 sets of 400 AU feeding a trough supplying 5 200A disconnects. In addition there is one 800A. disconnect supplied by 3 sets of 400 AU feeding a trough with 5 more 200A disconnects. This provides 6 disconnecting means for disconnecting the entire service per 230.71, and are grouped per 230.71. The 5 200A disconnects fed from the trough are to be labled Main 1-5, with the 800A disconnect being labled Main 6. This is fed from the same source transformer that is shown in the picture, which satisifies the one source end per 230.2.
The argument from the inspectional authourity is that the parallel feeds from the source do not terminate in the same trough or cabinet that this results in their being 2 services on the building and thus the violation.
Any insight or answers you can provide would be greatly appreciated.
Thank you ,
TC
Thank you ,
TC
