bphgravity
- Florida
Can a receptacle outlet be used as a distribution point and receiving point for a cord-and-plug switch?
For example, can I put a 120-volt supply conductor on one side of the receptacle, a load conductor on the other side and plug in a float switch to the receptacle.
I know there is a pump assembly that utilizes this type of setup external from the receptacle, but would this be a violation of the intended purpose of a recptacle?
I do not have an actual intention to do this, or can I provide a logical reason this may be a desired setup, its more out of curiosity.
