Violation?
jes25
Midwest
So I installed a trough off a resi meter socket so I could add a service disconnect. In that trough I connected the neutral to trough since it was fed with PVC conduit. I received this violation:
NEUTRAL CANNOT BE CONNECTED TO TROUGH, CONNECT BOND GROUND FROM MAIN DISCONNECT.
I thought, E3609.4.1 of the MRC (IRC to those not in the mitten state) specifically requires service raceways and enclosures to be connect to the grounded (neutral) conductor if they are not connected with metal threaded connections. I'm pretty sure the NEC has a similar requirement. Am I right? Or is the inspector?
He also cited me for not using antioxidant on my aluminum feeders, which I don't think is a violation either.
Anti-ox is not required on aluminum terminals unless it's part of the listing by the manufacturer (which is probably isn't). According to the NEC all metallic parts and raceways on the line side of the service disconnect are bonded to the neutral.
I agree with Infinity.
250.80 Service Raceways and Enclosures. Metal enclo- sures and raceways for service conductors and equipment shall be connected to the grounded system conductor if the electrical system is grounded or to the grounding electrode conductor for electrical systems that are not grounded.
This one too:
250.142 Use of Grounded Circuit Conductor for
Grounding Equipment.
(A) Supply-Side Equipment. A grounded circuit conduc-
tor shall be permitted to ground non–current-carrying metal
parts of equipment, raceways
, and other enclosures at any
of the following locations:
(1) On the supply side or within the enclosure of the ac
service-disconnecting means
(2) On the supply side or within the enclosure of the main
disconnecting means for separate buildings as provided
in 250.32(B)
(3) On the supply side or within the enclosure of the main
disconnecting means or overcurrent devices of a sepa-
rately derived system where permitted by 250.30(A)(1)
