Budweiser143
- West Palm Beach
Backstory: I'm a member to this site called instructables.com Someone did a write a up about "How to" clean your A/C unit. Link HERE Some comments were made by others about safety, and making sure your A/C unit was off, and doubling checking for voltage before beginning work.
Someone commented: "I have something better, as far as safety. I stood over my A/C installer and demanded they install a 240 V AC plug on the A/C unit, that plugs into a socket on the breaker box. Now when I need to do repairs or maintenance, I can unplug the unit and know it's dead. This is the same form of safety that is routinely performed when repairing vacuum cleaners, power saws, and the like. I am not comfortable working on any equipment that is hard-wired to the line through a box. One bump of a lever, or a sticking switch, and you're live! I have never seen electricity "jump" through a plug that has been pulled!
Before the wet cleaning is performed, a shop vacuum should be used to remove leaves and other dry matter, both inside and outside the unit."
To which I replied: "Im surprised your installer obliged as that is against electrical code and would be failed by any inspector. A/C units are to be hard wired, Just as hot water heaters are, with a means a of disconnect, within sight."
To which I got the following reply: "It is not against electrical code. The installer put in the disconnect box as usual, per code, but instead of hard-wiring the A/C unit, he put a socket in the cutoff box, and a cord/plug on the A/C unit. Read the rest of the comments on this subject! The first thing that is repeatedly mentioned is don't trust the cutoff switch! (I have seen one pole fail to disconnect because it rusted out). A plug, when removed, can always be trusted! I demanded the same for a bandsaw at work."
I could be wrong, but I see this as against code. If I'm right, how do I explain to this know it all that the only thing he knows is stupidity?
