Visual comfort Monorail (previously Tech Lighting)
JoeNorm
WA
Does anybody here have experience with this track light system? I got called in to troubleshoot flickering and intermittently working lights, as well as a humming sound. The connections feel rather loose, but I wasn't sure if that was just how the components fit. The owners said it has been a problem pretty much from the start. Any thoughts before I dive in?
this low-voltage track lighting is a prime example of customers choosing fashion over function.
IMO - low voltage lighting is just a pain.... originally, the main problem used to be the 5x amperes required to produce x-amount of watts of light, due to reducing the volts by 5x. with modern LED's today, that's not as much of an issue.
the second issue remains that, even just a little bit of corrosion is enough to cause problems across the 24v connections, which have much to be desired, already. and that's assuming you're not just having issues with all of he safeties in the driver-kit.
