RichyL said:
Ok so I am not a teacher, in fact I am a student, reading the categories though I figured this might be the best place to post as the instructors category is based on finding ways to help students understand electrical concepts. My question relates to if there is any visual (videos or diagrams) resources that show how electricity moves, specifically in 120/240 volt applications. In a straight 240 load with no neutral, (such as a water heater or electric furnace) I am led to believe the current travels in a circle that rotates. Such as moving from one hot on the breaker to the load then back through the other current carrying conductor towards the panel, then coming back to the load again from the opposite direction. There is no neutral load so I'm assuming the ground is only used to carry fault currents back to the neutral main to trip the breaker. That is what i got out of it anyway. As far as 120 volt goes (a basic 15 amp receptacle) or a range that has 2 hots and a neutral I'm a little confused. Is a 120 volt receptacle still considered alternating current since there is only 1 hot wire? My understanding of this is it goes in a circle from breaker to the hot to the neutral then neutral main to carry the balanced load. To me it sounds as if this is direct current. Any videos pics diagrams or explanations would be greatly appreciated. I did not see an electrical theory topic on the forums, so if there is a better place to post this please let me know. Thank you much
Rich
The difference between 120, with the neutral, and 240, without the neutral, is the range of voltages for each of the conductors.
For a 120 volt receptacle, the hot conductor starts off at 0 volts, goes 120 volts, turns around and goes back down towards 0, down towards -120 volts, turns around and goes back towards 0 again. The neutral conductor, all this time, has a constant voltage of 0. So, the difference between the hot and the neutral alternates between 0 and 120 volts.
For a 240 volt receptacle, the first hot conductor starts off at 0, goes up towards 120 volts, turns around, goes back towards 0, then goes down towards -120 volts, turns around, and goes back towards 0. At the same exact time, the second hot conductor starts off at 0, goes down to -120, back to 0, up to 120, then back to 0 again. So, the difference between the two hot conductors alternates between 0 and 240 volts. When L1 is at 0, L2 is at 0. When L1 is at +120 volts, L2 is at -120 volts, and when L1 is at -120 volts, L2 is at +120 volts.
In both circuit types, current moves from high voltage to low voltage. So, in a 120 voltage circuit, when the hot conduct is greater than 0, current flows from the hot conductor to the neutral, and when the hot conductor is less than 0, current flows from the neutral conductor to the hot conductor. This creates the circle that was described to you. In a 240 volt circuit, when L1 is greater than 0 volts, current flows from L1 to L2, and when L2 is greater than 0 volts, current flows from L2 to L1.
What happens in a 3-wire circuit where you have L1, L2 and neutral (N)? The current flows the same way -- from the higher voltage conductors to the lower voltage conductors. The difference is that there is a neutral conductor that always has a voltage of 0. So, if the current on L2 is 0, and the current on L1 is 1 ampere, there is no path for the L1 current to return through L2, so the L1 current returns using N. If the current on L1 is 0, the opposite happens. The L2 current returns using N.
What happens when there is a load on L1
and L2? Remember that current always flows from high voltage to low voltage. However much current is on L1 will return using L2 depending on how much current is on L1 and L2 and the difference in voltages. The difference in current between L1 and L2 will have to use N. So, if L1 has 1 ampere and L2 has 2 amperes, when L1 is greater than 0 and L2 is less than 0, one ampere will come from L1 and flow from L1 to L2 and one ampere come from N and flow from N to L2. When the voltages make it half way through the cycle and both are 0 again, the current changes direction. Now, there are 2 amperes coming from L2. One amp from L2 goes to L1, and the second amp goes to N. As you can see, there is always one amp on L1 -- it either comes from L1 through the circuit breaker, or from L2. There is also always one amp on N -- it either comes from the panel or from L2 as the difference between L1 and L2. And there is always 2 amps on L2 -- it either comes through the circuit break, or from N and L1.
Makes sense? Got questions?
Note: Don't any of you who know what's wrong with the numbers correct me about RMS voltage. As soon as the OP understands this, I'll explain RMS.
