I need to supply a 24V Engine with an incoming Voltage of 220V. The run from the batteries is to the engine will be 12M. The core cable i wish to use is a 70 sq mm cable and the batteries are 12V 880Amps. Please advise on the volt drop and how many batteries i need to set up to achieve this. It would be great to get a clear explanation as I want to learn rather than just get an answer.
Thanks
Thanks
