Volt Pen
I have had a milwaulkee , an ideal and a greenlee. I liked the milwaulkee and greenlee the best. If I had to pick one over the other I would pick Greenlee
Who makes the best volt-pen, in your opinion ?
My Fluke has worked well for years. But with all instrtumernts it is impasrastive not to simply trust them but to test it with a known voltage source first, then test for voltage presence or per the manufacturers instructions to assure that it is functioning, then retest for voltage with a known source.
The instructions with all of those devices say something like the following:
When using the Tester, if tip does not glow, voltage could still be present. (Fuke)
If no indication, voltage could still be present. (Klein)
Do not assume that no voltage indication means the circuit is de-energized. (Ideal)
The same caution should be used when using any type of test equipment.
Other types of test equipment can be tested using the live-dead-live method. Because of the way that non-contact testers work, you really can't do that with them. If the conditions on the known live source are not EXACTLY the same as the conditions on the circuit being tested, you have not really done a live-dead-live test.
Don you are correct. It is a tool and you need to know how to use it. Often we are testing a switch with no light and we want to make sure it is not hot. The light comes on when the switch is turned on then we know we are good and we can disconnect the wire with the switch off.
I would not want to cut into a wire with that as my only defense
