Eduardo Maun
- Qatar
I have read this " the higher the voltage the higher the current in a Electrical Estimate book under the Ohm's Law" but when I compare the 220/110 volts in a given load it goes the other way. For 220V given 5000 watts the current I got is 22.72A, for 110V the same load I got 45.45A. does the statemnet correct or its just a typograpical error? or there is an Theoretical / Technical answer for this? Power is the product of I squared times the resistance so the given load is not the resistance @ all. this is only the reason I see... can you explain it further to me.
Thank you!!!
Eduardo
Thank you!!!
Eduardo
