iwirehouses
I just got hired to do the wiring to replace a pump and floats in a septic tank. Wasn’t a bad job honestly. But there’s a controller inside the house where all the floats and pump run to. With an alarm on it. Everything‘s working fine. Except the pump turns on via a relay. With the coil, not energized in the relay, there is always 50 volt to the hot wire going out to the pump. Once the relays energized 120 V goes through the relay to the pump. And it turns on. Everything works fine. But I’m suspicious why there is 50 V bleeding through the relay and going out to the pump without the coil being energizer. The neutral doesn't bleed through the relay at all. Everything technically works fine. Wondering what I’m missing. Or if I should be concerned.
