I'm a plant engineer in an industrial facility that is supplied with a 240V Corner Grounded Delta System. I was called out to a machine that had tripped an O/L on motor. I reset the trip then disconnected power to the machine to measure voltage on the supply side of the disconnect. When I measured the voltage, the voltage was cycling from 240V to 160V up and down consistently. I've never seen this before...at a loss...it went away for sometime but when I went back later to measure it was back...any suggestions?
