Sorry, I should have been more descriptive on my question. I'm working on an old building on a military base and I have this case where there are two services coming into a building. One service is 440V (not 480V) and the other service is 220V (not 208V). Both services are 3 phase. The 440V service is feeding off a pole with 3-50KVA transformers and the 220V is feeding from another pole with 3-45KVA transformers. This is an old building I believe was built in the 60's. Anway, from the poles the feeders go underground into a vault to seperate main disconnects and then from the vault go underground into a wireway located in the main electrical room. From the wireway they branch off to a 440V 400A main fused disconnect and then a 400A 220V distribution panel.
My boss had told me that it is a code violation to have the 440V and 220V feeders in the same wireway with no seperation in the wireway. I went back to the office to try to find what Article states this but haven't been successful. Is this allowable per code? If not, what Article states it.
Thanks.
