staticcontrol
Hello everyone,
First, hope you're all going to have a great summer kick off this weekend.
I was approached to give a ball park estimate of what it would take to provide 200 amps in a warehouse that is 350 feet from main distribution.
I figure to use a 480v primary 208/120 v secondary 75 kva transformer located 350 feet away from main distribution. The Primary breaker size will be 125 amp disconnect. Can someone help size the wire given the distance because of voltage drop?
It's been a while. I came up with 1/0. after derating.
Thank you in advance.
static control
static control
