sparkync
- North Carolina
Customer has a outside "fountain pump" with a 1/2 hp motor. The length of the run is approximately 500 ft. I've punched it in 2 online calculators, and one tells me it would take #4 size copper wire. Seems way big. Another calculator says the voltage will only be 118 volts on #12 wire.
Don't seem to be consitant. Which one is right you think?
Thanks
Thanks
