slalom skier
- Royal Palm Beach FL. USA
To figure voltage drop on feeders coming off of a multi meter to 120/240 volt panels which voltage would I use along with load calculations?
I have always converted everything to VA or watts and assume i'll do a balanced panel or close enough.Seems to me this is a bit tricky with mixed 120V and 240V loads.
Yes, but I believe the worst case voltage drop (percentage wise) occurs when all the 240V loads are at full load, and half of the 120V loads are at full load, just the ones on a particular leg. So you need to track them separately and calculate for that case, with respect to 120V base voltage.I have always converted everything to VA or watts and assume i'll do a balanced panel or close enough.
