steveve1
- Tucson, AZ
Hello All and Merry Christmas from chilly Arizona, I'm wondering how having a VFD mounted a distance away from the motor affects voltage drop calculations. For example: A 10hp motor @ 480v, 100' feeder length. At nominal voltage I assume a load of 14a. VD calcs indicate a drop of 4.8v with #12cu conductors. Will the conductor size be adequate through the range of the applied voltage to the motor from the VFD? I have an installation with several VFD controlled motors, varying distances and HP. Is there a general "rule of thumb" or will standard VD calcs apply regardless of the VFD control?
Thanks in advance....and Happy Holidays!
