Re: Voltage drop calculation for long feeder run
Bruce, CM is "circular mills" and the 2 is for 2 conductors. Lets say you want to hold the voltage drop to no more than 3%
240 x .03 = 7.20 v
12.9 is just a standard for the constant of copper resistance. This number as Dereck pointed out is not accurate but is erred on the conservative side.
So if you were actually looking at a 100 amp load it would be; (we could shorten the calculation as Derck said, but lets go the long route this time)
2 x 12.9 x 100 x 150 = 387,000
387,000 / 7.2 = 53,750 circular mills.
Per table 8 this would be between #3 and #2 so the #2 would be the best choice.
Roger
