Voltage drop calculation method for LV distribution network
jimihieu
New member
Hi everyone,
Does anyone know any good method or algorithm to calculate Voltage drop for LV distribution network?
thank you
jimihieu said:
Hi everyone,
thank you
By networks do you mean several transformer sources tied together?
Well, I know the formula. If your good with excel you can create a spreadsheet where you just plug in the values.
Vd = voltage drop
I = current in conductor
L = One way lenght of circuit
CM = Cross sectional area of conductor (circular mils) - can find in NEC
K = resistance in ohms of 1 circular mil foot of conductor
K = 12.9 for copper @ 75 celcius
K = 21.2 for alumininum (i doubt your using aluminum)
Single Phase
Vd = 2K x L x I / Cm
Three Phase
Vd = 1.73K x L x I / Cm
Hope that helps
jimihieu said:
Hi everyone,
thank you
When calculating voltage drop for networks, I've found Excel to be quite useful. Purchasing one of the engineering level programs that will do the calculations somewhat automatically is not a justifiable expenditure for me.
