TacomaMike
I have a 120/240v 100 amp 1-phase panel with light load (about 15 amps). The pad mount trasformer feeding this panel is 1000' away. When calculating the wire size for the voltage drop do I use 100 amps or do I use 15 amps in the formula? (I realize this is fine assuming the load will never change).
Using the formula Vd = 2k x L x I / Cm
